Salta al contenuto principale
HP G72 WLAN module Replacement
Cosa ti serve
  1. HP G72 WLAN module Replacement, WLAN module: passo 1, immagine 1 di 3 HP G72 WLAN module Replacement, WLAN module: passo 1, immagine 2 di 3 HP G72 WLAN module Replacement, WLAN module: passo 1, immagine 3 di 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
  2. HP G72 WLAN module Replacement: passo 2, immagine 1 di 3 HP G72 WLAN module Replacement: passo 2, immagine 2 di 3 HP G72 WLAN module Replacement: passo 2, immagine 3 di 3
    • Loosen the three Phillips M2.5×6.0 captive screws that secure the memory module compartment cover.
    • Use a plastic opening tool (or equivalent) to lift the back side of the cover. Small tabs hold the cover in place. Firmly pull up on the cover to release the tabs.
    • Remove the cover
  3. HP G72 WLAN module Replacement: passo 3, immagine 1 di 3 HP G72 WLAN module Replacement: passo 3, immagine 2 di 3 HP G72 WLAN module Replacement: passo 3, immagine 3 di 3
    • Disconnect the main antenna cable
    • Disconnect the auxiliary antenna cable
    • Remove the Phillips M2.0×3.0 screw that secures the WLAN module to the computer.
  4. HP G72 WLAN module Replacement: passo 4, immagine 1 di 1
    • Remove the WLAN module by pulling it away from the slot at an angle.
Conclusione
oldturkey03
Membro da: 09/29/10
782.439 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
544 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,010
