Introduzione
This guide will show the user how to remove the optical drive.
Parti
Nessuna parte richiesta.
Removing the battery while the laptop is still on may corrupt your files. Turn the device over to expose the bottom of the device.
  • Removing the battery while the laptop is still on may corrupt your files.
  • Turn the device over to expose the bottom of the device.
  • Slide the battery release all the way to the left.
  • There will be a click and the battery will be released from its compartment.
Aggiungi Commento
Carefully remove the battery from its compartment.
  • Carefully remove the battery from its compartment.
Aggiungi Commento
Locate two Phillips head retaining screws which secure the hard drive compartment.
  • Locate two Phillips head retaining screws which secure the hard drive compartment.
  • Use a Phillips #0 screwdriver to loosen the retaining screws.
  • Remove the panel covering the compartment.
  • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
Aggiungi Commento
Locate the 6 mm Phillips head screw to the left of the hard drive.
  • Locate the 6 mm Phillips head screw to the left of the hard drive.
  • Use a Phillips #0 screwdriver to remove the screw.
Aggiungi Commento
Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive. Apply enough pressure to loosen the optical drive.
  • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
  • Apply enough pressure to loosen the optical drive.
  • The optical drive can then be removed by hand.
Aggiungi Commento
Conclusione
Garret Layton
Membro da: 13/01/2015
627 Reputazione
5 Guide realizzate
USF Tampa, Team 1-4, Sullivan Winter 2015 Membro di USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 605
