Introduzione
The fan in your laptop keeps the device from overheating. Your device is prone to overheating due to numerous causes. Some of those causes can be the following: too many applications are running, device doesn’t have the specifications to run certain applications, etc. When your device overheats, some of the components in your device are likely to fail.
If the CPU fan in your HP Envy x360 m6-aq003dx is not working properly, follow this guide to remove the fan from your laptop.
Cosa ti serve
Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
Remove the cable from the connector.
