Salta al contenuto principale
HP Envy x360 15-u473cl Touch Screen Replacement
Cosa ti serve
  1. HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: passo 1, immagine 1 di 2 HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: passo 1, immagine 2 di 2
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. HP Envy x360 15-u473cl Touch Screen Replacement: passo 2, immagine 1 di 1
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. HP Envy x360 15-u473cl Touch Screen Replacement: passo 3, immagine 1 di 1
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. HP Envy x360 15-u473cl Touch Screen Replacement: passo 4, immagine 1 di 2 HP Envy x360 15-u473cl Touch Screen Replacement: passo 4, immagine 2 di 2
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 47
Tutti i Tempi: 12,742
