Salta al contenuto principale
HP Envy TouchSmart 15 Wireless Adapter Replacement
Cosa ti serve
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: passo 1, immagine 1 di 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: passo 3, immagine 1 di 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: passo 3, immagine 2 di 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, immagine 1 di 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, immagine 2 di 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, immagine 3 di 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: passo 5, immagine 1 di 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: passo 5, immagine 2 di 2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, immagine 1 di 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, immagine 2 di 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, immagine 3 di 3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 2-6, Sullivan Fall 2015 Membro di USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Membri
10 Guide realizzate
Un commento
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,111
