Salta al contenuto principale
HP Elitebook 8460p Cooling Fan Replacement
Cosa ti serve
  1. HP Elitebook 8460p Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Cooling Fan Replacement, Back Panel: passo 3, immagine 1 di 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: passo 5, immagine 1 di 2 HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: passo 5, immagine 2 di 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Cooling Fan Replacement: passo 6, immagine 1 di 2 HP Elitebook 8460p Cooling Fan Replacement: passo 6, immagine 2 di 2
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Cooling Fan Replacement: passo 7, immagine 1 di 2 HP Elitebook 8460p Cooling Fan Replacement: passo 7, immagine 2 di 2
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Cooling Fan Replacement: passo 8, immagine 1 di 1
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Cooling Fan Replacement: passo 9, immagine 1 di 2 HP Elitebook 8460p Cooling Fan Replacement: passo 9, immagine 2 di 2
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Cooling Fan Replacement: passo 10, immagine 1 di 1
    • Blow compressed air through the vent from the outside and through the heat sink.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 46
Tutti i Tempi: 4,464
