Salta al contenuto principale
HP EliteBook 840 G5 WIFI Card Replacement
Cosa ti serve
  1. HP EliteBook 840 G5 WIFI Card Replacement, Back Cover: passo 1, immagine 1 di 2 HP EliteBook 840 G5 WIFI Card Replacement, Back Cover: passo 1, immagine 2 di 2
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 WIFI Card Replacement: passo 2, immagine 1 di 3 HP EliteBook 840 G5 WIFI Card Replacement: passo 2, immagine 2 di 3 HP EliteBook 840 G5 WIFI Card Replacement: passo 2, immagine 3 di 3
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 WIFI Card Replacement: passo 3, immagine 1 di 1
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
  4. HP EliteBook 840 G5 WIFI Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 3 HP EliteBook 840 G5 WIFI Card Replacement, Wi-Fi Card: passo 4, immagine 2 di 3 HP EliteBook 840 G5 WIFI Card Replacement, Wi-Fi Card: passo 4, immagine 3 di 3
    • Using either the spudger, tweezers or your fingers, remove the wire connectors from the WiFi card by pulling up.
    • The wire connectors should disconnect from the WiFi card with minimal force; Refrain from pulling too hard, as you might damage the WiFi card further.
  5. HP EliteBook 840 G5 WIFI Card Replacement: passo 5, immagine 1 di 1
    • Remove the single 2mm screw that is holding the WiFi card in place using the Phillips #1 screwdriver.
  6. HP EliteBook 840 G5 WIFI Card Replacement: passo 6, immagine 1 di 2 HP EliteBook 840 G5 WIFI Card Replacement: passo 6, immagine 2 di 2
    • The WiFi card will pop up. Carefully grasp both sides of the card and pull outwards, away from its dock.
    • The WiFi card should be removed easily with minimal force; Refrain from pulling too hard.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure to handle the component with extreme care, as it is delicate and has no protection.
Cal Poly, Team S25-G13, Maness Spring 2018 Membro di Cal Poly, Team S25-G13, Maness Spring 2018
CPSU-MANESS-S18S25G13
4 Membri
18 Guide realizzate
Un commento
It is not that helpful if there is no mention of the card model, form-factor, specifications of the original wifi card. which opens potential upgrades
Jay Son - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 102
Tutti i Tempi: 6,766
