Introduzione
If it is apparent that there are problems regarding the paper being fed through the HP Deskjet F4480, replacing the paper roller motor is a possible solution. The paper roller motor controls the paper rollers ability to pull paper into the printer and across the ink cartridges for proper printing.
Cosa ti serve
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Detach the white ribbon cable.
Remove the two 9mm Torx screws on either side of the white bracket.
To reassemble your device, with the addition of a new motor, follow these instructions in reverse order.
Altre 7 persone hanno completato questa guida.
