Introduzione
If the printed page appears with streaks, faded colors, or incorrect colors, replacing the ink cartridges is a possible solution. New ink cartridges improve the quality and appearance of the printed document.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Open the front access panel by placing your finger in the front slot and pulling gently.
  • Open the front access panel by placing your finger in the front slot and pulling gently.
Aggiungi Commento
Slide the ink carriage until the the cartridges line up with the marked slots in the middle.
  • Slide the ink carriage until the the cartridges line up with the marked slots in the middle.
  • If the printer is on, then the carriage should have automatically slid to the middle when the front was opened. If not, ensure printer is unplugged and slide manually.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Gently, but firmly depress the front of the ink cartridge you are removing until it is loose. There may be a faint click when the cartridge comes loose.
  • Gently, but firmly depress the front of the ink cartridge you are removing until it is loose.
  • There may be a faint click when the cartridge comes loose.
Aggiungi Commento
Gently slide out cartridge.
  • Gently slide out cartridge.
  • Don't make contact with the ink head. The ink likes to get everywhere.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Tom Higdon
Membro da: 15/01/2013
321 Reputazione
1 Guida realizzata
Cal Poly, Team 18-35, Regan Winter 2013 Membro di Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 Membri
8 Guide realizzate
pls help me to operate to restore my hp deskjet f4480, I removed last wk the catridges to refill but when i starting to put back the catriges, i cant move the catriges holder, give me some tips pls, hoping a lot, ty
rico timbol - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 118
Tutti i Tempi: 11,582
