Salta al contenuto principale
HP Deskjet D1660 Encoder Strip Replacement
Cosa ti serve
  1. HP Deskjet D1660 Encoder Strip Replacement, Encoder Strip: passo 1, immagine 1 di 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Encoder Strip Replacement: passo 2, immagine 1 di 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Encoder Strip Replacement: passo 3, immagine 1 di 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Encoder Strip Replacement: passo 4, immagine 1 di 3 HP Deskjet D1660 Encoder Strip Replacement: passo 4, immagine 2 di 3 HP Deskjet D1660 Encoder Strip Replacement: passo 4, immagine 3 di 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Encoder Strip Replacement: passo 5, immagine 1 di 3 HP Deskjet D1660 Encoder Strip Replacement: passo 5, immagine 2 di 3 HP Deskjet D1660 Encoder Strip Replacement: passo 5, immagine 3 di 3
    • Looking at the printer from the front, carefully unhook the encoder strip from the left side.
    • Pull the strip to the left and push a little to unhook the strip.
    • Do the same thing on the other side by pulling to the right and pushing a little.
    • Pull the strip completely out from the cartridge holder.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 1-41, Maness Winter 2014 Membro di Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 4,268
