Introduzione
This replacement is moderately difficult to complete, and requires about one hour of time. These belts often become worn down because they are in constant motion when the printer is printing. Replacing a worn down or broken belt will add years to the printer's lifespan.
Begin to disassemble the printer by disconnecting from all power sources and computers.  Keep cords separate and allow the printer to cool for 5 minutes.
  • Begin to disassemble the printer by disconnecting from all power sources and computers. Keep cords separate and allow the printer to cool for 5 minutes.
Aggiungi Commento
Flip the printer upside down and locate the cover on the left hand side.  It is rectangular shape and is held in place by two screws.  Unscrew these screws and take off cover.
  • Flip the printer upside down and locate the cover on the left hand side. It is rectangular shape and is held in place by two screws. Unscrew these screws and take off cover.
Aggiungi Commento
To release the tray from the printer, you must manually pull it out.  Hold the tray and push towards one side of the printer.  Then pull away from the printer towards the other side.  Keep output tray separate.
  • To release the tray from the printer, you must manually pull it out. Hold the tray and push towards one side of the printer. Then pull away from the printer towards the other side. Keep output tray separate.
Aggiungi Commento
Turn the printer upside down.  Locate the four screws holding the cover in place. These will be on the edges of the cover.
  • Turn the printer upside down. Locate the four screws holding the cover in place. These will be on the edges of the cover.
Aggiungi Commento
Unscrew the four screws, keeping them separate.  Turn the printer back right side up
  • Unscrew the four screws, keeping them separate. Turn the printer back right side up
Aggiungi Commento
Place fingers on the edge of the red cover.  Begin to pull upwards to release the top portion, working your way around the printer.  Make sure that it does not fall back into place.
  • Place fingers on the edge of the red cover. Begin to pull upwards to release the top portion, working your way around the printer. Make sure that it does not fall back into place.
Aggiungi Commento
Once the top is loose, there will still be a connection wire between the printer and the cover.  This wire will be about one inch wide and white, located under the buttons. Once the top is loose, there will still be a connection wire between the printer and the cover.  This wire will be about one inch wide and white, located under the buttons.
  • Once the top is loose, there will still be a connection wire between the printer and the cover. This wire will be about one inch wide and white, located under the buttons.
Aggiungi Commento
Detach the wire from the printer by pulling the blue-sealed end from the white holder. Detach the wire from the printer by pulling the blue-sealed end from the white holder.
  • Detach the wire from the printer by pulling the blue-sealed end from the white holder.
Aggiungi Commento
The hard drive is in the upper left hand corner of the printer.  Locate, then unscrew, the three screws that are holding it in place.  Take not of the size of the screws and where they were located.
  • The hard drive is in the upper left hand corner of the printer. Locate, then unscrew, the three screws that are holding it in place. Take not of the size of the screws and where they were located.
Aggiungi Commento
Pull the narrower cord out of its connection, holding the blue-sealed end.
  • Pull the narrower cord out of its connection, holding the blue-sealed end.
Aggiungi Commento
Move the hard drive forward and angle downwards so that the larger cord is easier to hold.  Pull out of connection holding the cord from the blue-sealed end.
  • Move the hard drive forward and angle downwards so that the larger cord is easier to hold. Pull out of connection holding the cord from the blue-sealed end.
Aggiungi Commento
The hard drive will remain loosely attached because of the wires.  Do not disconnect these, but lift out of the printer.
  • The hard drive will remain loosely attached because of the wires. Do not disconnect these, but lift out of the printer.
Aggiungi Commento
Locate the belt, and the wheel it is around.  The wheel will be on top of the metal piece on the far right side.
  • Locate the belt, and the wheel it is around. The wheel will be on top of the metal piece on the far right side.
Aggiungi Commento
Pull the belt tightly to this side, creating enough slack to lift the belt from the wheel.
  • Pull the belt tightly to this side, creating enough slack to lift the belt from the wheel.
Aggiungi Commento
Push the ink cartridge to the center of the printer so that the wheel on the opposite side is visible.  Then lift the belt from that wheel.
  • Push the ink cartridge to the center of the printer so that the wheel on the opposite side is visible. Then lift the belt from that wheel.
Aggiungi Commento
Locate the narrow hard drive on the left side of the printer.  Unscrew the screw holding it in place, then disconnect the cord.
  • Locate the narrow hard drive on the left side of the printer. Unscrew the screw holding it in place, then disconnect the cord.
Aggiungi Commento
Remove the hard drive, keeping separate from printer.
  • Remove the hard drive, keeping separate from printer.
Aggiungi Commento
Unscrew the screws that are holding the metal structure in place.  This includes the screw that is on the right side near the wheel the carriage driver belt was around. Be sure to note the size of the screws and where they go.
  • Unscrew the screws that are holding the metal structure in place. This includes the screw that is on the right side near the wheel the carriage driver belt was around. Be sure to note the size of the screws and where they go.
Aggiungi Commento
On the left side, between the wall of the printer and the metal piece, there will be a spring connecting the two.  Use the tweezers to detach the spring and keep separate.
  • On the left side, between the wall of the printer and the metal piece, there will be a spring connecting the two. Use the tweezers to detach the spring and keep separate.
Aggiungi Commento
On the right side of the printer there will also be a spring.  Again, disconnect this spring using the tweezers.
  • On the right side of the printer there will also be a spring. Again, disconnect this spring using the tweezers.
Aggiungi Commento
Now releasing the metal structure will be possible.  On the left side of the structure, locate the wheel that the Carriage Driver Belt was around.  Push this wheel through the larger opening it sits in.
  • Now releasing the metal structure will be possible. On the left side of the structure, locate the wheel that the Carriage Driver Belt was around. Push this wheel through the larger opening it sits in.
Aggiungi Commento
Lift the metal structure from the printer, which will include the ink cartridge holders.
  • Lift the metal structure from the printer, which will include the ink cartridge holders.
Aggiungi Commento
Locate the metal bar that will be running parallel to the metal structure that was just removed.  Locate the washer at one end.
  • Locate the metal bar that will be running parallel to the metal structure that was just removed. Locate the washer at one end.
Aggiungi Commento
Use the tweezers to pry off the washer, then slide the belt out.  Lift the ink cartridge holder from the metal piece, separating the two.
  • Use the tweezers to pry off the washer, then slide the belt out. Lift the ink cartridge holder from the metal piece, separating the two.
Aggiungi Commento
Locate the white, ink cartridge holder.  Find the three connections to the black part, this will be towards the base where the white paper is.
  • Locate the white, ink cartridge holder. Find the three connections to the black part, this will be towards the base where the white paper is.
Aggiungi Commento
Push the white connections out of where they are held in the black part.  This will detach the cartridge holder.
  • Push the white connections out of where they are held in the black part. This will detach the cartridge holder.
Aggiungi Commento
On the cartridge holder, locate the screws holding the green hard drive in place.  Unscrew these screws.
  • On the cartridge holder, locate the screws holding the green hard drive in place. Unscrew these screws.
Aggiungi Commento
On the front portion, detach the white paper from the holder.  There will be six tabs that can be pushed though the paper to do this.
  • On the front portion, detach the white paper from the holder. There will be six tabs that can be pushed though the paper to do this.
Aggiungi Commento
Thread the white paper through the whole so that the latch holding the cartridge belt is visible.
  • Thread the white paper through the whole so that the latch holding the cartridge belt is visible.
Aggiungi Commento
Locating where the belt is held in place, there will be a metal cover protecting it.  To remove this piece, use the tweezers to push the tabs holding it in place off.
  • Locating where the belt is held in place, there will be a metal cover protecting it. To remove this piece, use the tweezers to push the tabs holding it in place off.
Aggiungi Commento
  • This will release the belt. Discard the old belt and place the new one on.
Aggiungi Commento
Conclusione
tdambruoso
Membro da: 20/10/2014
401 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 1-5, Duarte Fall 2014 Membro di UMass Dartmouth, Team 1-5, Duarte Fall 2014
UMASSD-DUARTE-F14S1G5
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 389
