Salta al contenuto principale
HP Deskjet 3000 j310a Ink Cartridge Holder Replacement
Cosa ti serve
  1. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Disconnect Printer: passo 1, immagine 1 di 1
    • Begin to disassemble the printer by disconnecting from all power sources and computers. Keep cords separate and allow the printer to cool for 5 minutes.
  2. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Remove Bottom Cover: passo 2, immagine 1 di 1
    • Flip the printer upside down and locate the cover on the left hand side. It is rectangular shape and is held in place by two screws. Unscrew these screws and take off cover.
  3. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Release Paper Output Tray: passo 3, immagine 1 di 1
    • To release the tray from the printer, you must manually pull it out. Hold the tray and push towards one side of the printer. Then pull away from the printer towards the other side. Keep output tray separate.
  4. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Unscrew Cover: passo 4, immagine 1 di 1
    • Turn the printer upside down. Locate the four screws holding the cover in place. These will be on the edges of the cover.
  5. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 5, immagine 1 di 1
    • Unscrew the four screws, keeping them separate. Turn the printer back right side up
  6. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Pull Off Top: passo 6, immagine 1 di 1
    • Place fingers on the edge of the red cover. Begin to pull upwards to release the top portion, working your way around the printer. Make sure that it does not fall back into place.
  7. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Disconnect Cover: passo 7, immagine 1 di 2 HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Disconnect Cover: passo 7, immagine 2 di 2
    • Once the top is loose, there will still be a connection wire between the printer and the cover. This wire will be about one inch wide and white, located under the buttons.
  8. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 8, immagine 1 di 2 HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 8, immagine 2 di 2
    • Detach the wire from the printer by pulling the blue-sealed end from the white holder.
  9. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Remove Large Hard Drive: passo 9, immagine 1 di 1
    • The hard drive is in the upper left hand corner of the printer. Locate, then unscrew, the three screws that are holding it in place. Take not of the size of the screws and where they were located.
  10. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Detach the White Cords: passo 10, immagine 1 di 1
    • Pull the narrower cord out of its connection, holding the blue-sealed end.
  11. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 11, immagine 1 di 1
    • Move the hard drive forward and angle downwards so that the larger cord is easier to hold. Pull out of connection holding the cord from the blue-sealed end.
  12. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 12, immagine 1 di 1
    • The hard drive will remain loosely attached because of the wires. Do not disconnect these, but lift out of the printer.
  13. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Disconnect the Carriage Driver Belt: passo 13, immagine 1 di 1
    • Locate the belt, and the wheel it is around. The wheel will be on top of the metal piece on the far right side.
  14. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 14, immagine 1 di 1
    • Pull the belt tightly to this side, creating enough slack to lift the belt from the wheel.
  15. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 15, immagine 1 di 1
    • Push the ink cartridge to the center of the printer so that the wheel on the opposite side is visible. Then lift the belt from that wheel.
  16. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Remove Narrow Hard Drive: passo 16, immagine 1 di 1
    • Locate the narrow hard drive on the left side of the printer. Unscrew the screw holding it in place, then disconnect the cord.
  17. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 17, immagine 1 di 1
    • Remove the hard drive, keeping separate from printer.
  18. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Unscrew Metal Structure: passo 18, immagine 1 di 1
    • Unscrew the screws that are holding the metal structure in place. This includes the screw that is on the right side near the wheel the carriage driver belt was around. Be sure to note the size of the screws and where they go.
  19. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Disconnect Springs: passo 19, immagine 1 di 1
    • On the left side, between the wall of the printer and the metal piece, there will be a spring connecting the two. Use the tweezers to detach the spring and keep separate.
  20. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 20, immagine 1 di 1
    • On the right side of the printer there will also be a spring. Again, disconnect this spring using the tweezers.
  21. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Remove Metal Structure: passo 21, immagine 1 di 1
    • Now releasing the metal structure will be possible. On the left side of the structure, locate the wheel that the Carriage Driver Belt was around. Push this wheel through the larger opening it sits in.
  22. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 22, immagine 1 di 1
    • Lift the metal structure from the printer, which will include the ink cartridge holders.
  23. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Remove Metal Bar: passo 23, immagine 1 di 1
    • Locate the metal bar that will be running parallel to the metal structure that was just removed. Locate the washer at one end.
  24. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 24, immagine 1 di 1
    • Use the tweezers to pry off the washer, then slide the belt out. Lift the ink cartridge holder from the metal piece, separating the two.
  25. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement, Remove Ink Cartridge Holder: passo 25, immagine 1 di 1
    • Locate the white portion of the ink cartridge holder, and find the three connections to the black portion.
  26. HP Deskjet 3000 j310a Ink Cartridge Holder Replacement: passo 26, immagine 1 di 1
    • At the three connections, push the white part out of the black openings. This will separate the white and black parts.
    • Insert the new ink cartridge holder where the previous one was.
Conclusione
tdambruoso
Membro da: 10/20/14
491 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 1-5, Duarte Fall 2014 Membro di UMass Dartmouth, Team 1-5, Duarte Fall 2014
UMASSD-DUARTE-F14S1G5
3 Membri
14 Guide realizzate
Un commento
Try printing and if the error still persists, remove all forms of network connection with the printer. Print a test page to ascertain that the printer does not suffer any hardware related issue. If it works, this issue is to do with the print job.https://www.hpsupport365.com/blog/how-to...
Alice Bolt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,374
