Salta al contenuto principale
HP Chromebook 11 G6 EE Battery Replacement
Cosa ti serve
  1. HP Chromebook 11 G6 EE Battery Replacement, Remove keyboard screws: passo 1, immagine 1 di 1
    • Remove the screws from the bottom case.
    • Two M2.5x8 PH1 screws.
    • Six M2.5x6 PH1 screws.
  2. HP Chromebook 11 G6 EE Battery Replacement, Remove keyboard: passo 2, immagine 1 di 2 HP Chromebook 11 G6 EE Battery Replacement, Remove keyboard: passo 2, immagine 2 di 2
    • Use a plastic opening pick to release the clips that secure the keyboard.
    • Avoid too much prying force. If you pry too hard, you'll break your pick. The trick is to get the pick in just a little bit, and then run it along the edge of the device.
    • DO NOT use metal tools for this step.
  3. HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: passo 3, immagine 1 di 1
    • Lift up the keyboard part way, being careful to not put stress on the keyboard and touchpad ribbon cables.
  4. HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: passo 4, immagine 1 di 3 HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: passo 4, immagine 2 di 3 HP Chromebook 11 G6 EE Battery Replacement, Disconnect keyboard: passo 4, immagine 3 di 3
    • Disconnect the keyboard ZIF connector
  5. HP Chromebook 11 G6 EE Battery Replacement, Disconnect touchpad: passo 5, immagine 1 di 2 HP Chromebook 11 G6 EE Battery Replacement, Disconnect touchpad: passo 5, immagine 2 di 2
    • Disconnect touchpad ZIF connector.
    • Now you can remove the keyboard assembly completely.
    • If your replacement keyboard came with touchpad and cable, you can start reassembling the computer now. If you need to retrieve the touchpad from the old keyboard, keep reading.
  6. HP Chromebook 11 G6 EE Battery Replacement, Remove touchpad: passo 7, immagine 1 di 1
    • Lift up the plastic guard covering the three PH0 M2x2 screws and remove them.
    • Lift the touchpad out and place into new keyboard.
    • Be sure to evenly tighten the touchpad screws during reinstallation. Even a small variance can lead to a touchpad that feels "off".
  7. HP Chromebook 11 G6 EE Battery Replacement, Battery: passo 8, immagine 1 di 3 HP Chromebook 11 G6 EE Battery Replacement, Battery: passo 8, immagine 2 di 3 HP Chromebook 11 G6 EE Battery Replacement, Battery: passo 8, immagine 3 di 3
    • Detach the battery from the motherboard.
  8. HP Chromebook 11 G6 EE Battery Replacement: passo 9, immagine 1 di 2 HP Chromebook 11 G6 EE Battery Replacement: passo 9, immagine 2 di 2
    • Unscrew the battery from the shell of the laptop.
  9. HP Chromebook 11 G6 EE Battery Replacement: passo 10, immagine 1 di 1
    • Gently lift the battery from the laptop frame.
Conclusione
Un commento
missing instructions. To remove the battery you need to remove the speakers and unscrew 2# m2 ph 2.2mm screws. Also unlisted screw sizes and amounts on number 9
Joshua Taylor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 764
