Salta al contenuto principale
HP Chromebook 11 G3 Battery Replacement
Cosa ti serve
  1. HP Chromebook 11 G3 Battery Replacement, Keyboard Mount: passo 1, immagine 1 di 2 HP Chromebook 11 G3 Battery Replacement, Keyboard Mount: passo 1, immagine 2 di 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Battery Replacement: passo 2, immagine 1 di 2 HP Chromebook 11 G3 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Battery Replacement: passo 3, immagine 1 di 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Battery Replacement: passo 4, immagine 1 di 3 HP Chromebook 11 G3 Battery Replacement: passo 4, immagine 2 di 3 HP Chromebook 11 G3 Battery Replacement: passo 4, immagine 3 di 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Battery Replacement: passo 5, immagine 1 di 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Gently remove the battery’s rainbow-colored bundled cable from the motherboard.
  7. HP Chromebook 11 G3 Battery Replacement: passo 7, immagine 1 di 2 HP Chromebook 11 G3 Battery Replacement: passo 7, immagine 2 di 2
    • Remove the six 4 mm Phillips #00 screws located along the perimeter of the battery.
  8. HP Chromebook 11 G3 Battery Replacement: passo 8, immagine 1 di 1
    • Lift out the battery.
    • The laptop may tip backwards onto its lid due to uneven weight distribution.
Conclusione
Altre 5 persone hanno completato questa guida.
Rahul Goyal
Membro da: 04/26/17
1.369 Reputazione
10 Guide realizzate
Cal Poly, Team S23-G3, Livingston Spring 2017 Membro di Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Membri
12 Guide realizzate
Un commento
Can the HP Chromebook 11 G3 be operated from the power adapter after the battery has been removed?
Andrew Logan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,707
