Parti
Nessuna parte richiesta.
Insert the plastic opening tool between the digitizer and the case.
  • Insert the plastic opening tool between the digitizer and the case.
  • Place the spudger in the gap created by the plastic opening tool to assist in separation.
Aggiungi Commento
Slide the spudger along the perimeter of the device to fully separate the two pieces. Slide the spudger along the perimeter of the device to fully separate the two pieces.
  • Slide the spudger along the perimeter of the device to fully separate the two pieces.
Aggiungi Commento
Use your fingers to pop the screen out from the digitizer. Use your fingers to pop the screen out from the digitizer.
  • Use your fingers to pop the screen out from the digitizer.
Aggiungi Commento
With the plastic opening tool, lift the black latch up.
  • With the plastic opening tool, lift the black latch up.
Aggiungi Commento
Pull the optical cord out from the motherboard.
  • Pull the optical cord out from the motherboard.
Aggiungi Commento
Conclusione
USF Tampa, Team 7-6, Remmell Winter 2015 Membro di USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 165
