Introduzione
This guide will teach the user how to install the left side panel and align the "mode" button correctly. It will also show the proper placement of the button to restore the device to its retail form.
Parti
Nessuna parte richiesta.
Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
Aggiungi Commento
Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
  • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
  • Remove the button from the side panel.
Aggiungi Commento
Ensure that the elevated grating is on the right side of the button in respect to the panel position seen in the first image. Insert the button into the side panel's designated slot using your fingers or tweezers if necessary.
  • Ensure that the elevated grating is on the right side of the button in respect to the panel position seen in the first image.
  • Insert the button into the side panel's designated slot using your fingers or tweezers if necessary.
Aggiungi Commento
Insert the top arc of the side panel into the top end of the device's side as seen in the second image. Insert the top arc of the side panel into the top end of the device's side as seen in the second image.
  • Insert the top arc of the side panel into the top end of the device's side as seen in the second image.
Aggiungi Commento
Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely. Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely.
  • Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely.
Aggiungi Commento
Conclusione
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
Membro da: 09/03/2012
101 Reputazione
9 Guide realizzate
Clemson, Team 15-3, Benson Spring 2012 Membro di Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 881
