Introduzione
This guide will teach you how to remove the circuit board from the device. This will allow the simple installation of the LCD screen cover.
Parti
Nessuna parte richiesta.
Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
Aggiungi Commento
Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
  • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
  • Remove the button from the side panel.
Aggiungi Commento
Use the plastic opening tool.
  • Use the plastic opening tool.
  • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
Aggiungi Commento
The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
  • The side panel can now be detached using your fingers.
  • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
Aggiungi Commento
The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel. The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
  • The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
Aggiungi Commento
Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel. Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel.
  • Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel.
Aggiungi Commento
The screen cover can be easily lifted and removed from the LCD screen.
  • The screen cover can be easily lifted and removed from the LCD screen.
Aggiungi Commento
Place the screen cover on top of the LCD so it covers its entirety and carefully slide the circuit board/LCD back into the device. Place the screen cover on top of the LCD so it covers its entirety and carefully slide the circuit board/LCD back into the device.
  • Place the screen cover on top of the LCD so it covers its entirety and carefully slide the circuit board/LCD back into the device.
Aggiungi Commento
Conclusione
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
Membro da: 09/03/2012
101 Reputazione
9 Guide realizzate
Clemson, Team 15-3, Benson Spring 2012 Membro di Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 891
