Introduzione
If the pictures or video are fuzzy or unable to focus, the lens may need replacement. Follow this guide to do so.
Cosa ti serve
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
Using a #00 Phillips head screwdriver, remove the following screws:
Three 2 mm screw
Altre 5 persone hanno completato questa guida.
Un commento
Between step 6 and step 7, you skipped a really important step…
