Salta al contenuto principale
GoPro Hero3+ Silver Edition Front Panel Replacement
Cosa ti serve
  1. GoPro Hero3+ Silver Edition Front Panel Replacement, Front Panel: passo 1, immagine 1 di 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  2. GoPro Hero3+ Silver Edition Front Panel Replacement: passo 2, immagine 1 di 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 5-8, Maness Fall 2015 Membro di Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 570
