Salta al contenuto principale
GoPro Hero LCD Screen Replacement
Cosa ti serve
  1. GoPro Hero LCD Screen Replacement, Casing: passo 1, immagine 1 di 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: passo 2, immagine 1 di 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: passo 6, immagine 1 di 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 2 GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, immagine 2 di 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero LCD Screen Replacement: passo 8, immagine 1 di 1
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: passo 9, immagine 1 di 1
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: passo 10, immagine 1 di 2 GoPro Hero LCD Screen Replacement: passo 10, immagine 2 di 2
    • Separate the LCD screen from the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
River Drake
Membro da: 04/02/15
1.035 Reputazione
5 Guide realizzate
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro di Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membri
18 Guide realizzate
3 Commenti
Where do you buy the replacement lcd
Anthony Volatile - Replica
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING -
I can find the screen but is it compatible with the Hero+
Brian Casado - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 74
Ultimi 30 Giorni: 328
Tutti i Tempi: 22,626
