Salta al contenuto principale
GoPro Hero 3 Silver Image Sensor Replacement
Cosa ti serve
  1. GoPro Hero 3 Silver Image Sensor Replacement, Battery: passo 1, immagine 1 di 2 GoPro Hero 3 Silver Image Sensor Replacement, Battery: passo 1, immagine 2 di 2
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Image Sensor Replacement: passo 2, immagine 1 di 1
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: passo 3, immagine 1 di 2 GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: passo 3, immagine 2 di 2
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Image Sensor Replacement: passo 4, immagine 1 di 2 GoPro Hero 3 Silver Image Sensor Replacement: passo 4, immagine 2 di 2
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Image Sensor Replacement: passo 5, immagine 1 di 2 GoPro Hero 3 Silver Image Sensor Replacement: passo 5, immagine 2 di 2
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Image Sensor Replacement: passo 6, immagine 1 di 2 GoPro Hero 3 Silver Image Sensor Replacement: passo 6, immagine 2 di 2
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Image Sensor Replacement: passo 7, immagine 1 di 2 GoPro Hero 3 Silver Image Sensor Replacement: passo 7, immagine 2 di 2
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  8. GoPro Hero 3 Silver Image Sensor Replacement: passo 8, immagine 1 di 2 GoPro Hero 3 Silver Image Sensor Replacement: passo 8, immagine 2 di 2
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • You should now be able to remove the image sensor by simply pulling it.
Conclusione
Altre 2 persone hanno completato questa guida.
Jose Villa
Membro da: 04/01/15
297 Reputazione
1 Guida realizzata
Cal Poly, Team 24-7, Lancaster Spring 2015 Membro di Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Membri
21 Guide realizzate
2 Commenti
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - Replica
Your pictures are really dark.
Nick Ruiz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,863
