Salta al contenuto principale
Giant Reign 2 Wheel Spoke Replacement
Cosa ti serve
  1. Giant Reign 2 Wheel Spoke Replacement, Hex Screws: passo 1, immagine 1 di 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Wheel Spoke Replacement, Axle Screw: passo 2, immagine 1 di 2 Giant Reign 2 Wheel Spoke Replacement, Axle Screw: passo 2, immagine 2 di 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Wheel Spoke Replacement: passo 3, immagine 1 di 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Wheel Spoke Replacement, Front Wheel: passo 4, immagine 1 di 1
    • Pull the wheel from the fork.
  5. Giant Reign 2 Wheel Spoke Replacement, Tire Valve: passo 5, immagine 1 di 3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: passo 5, immagine 2 di 3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: passo 5, immagine 3 di 3
    • Twist and pull off the cap covering the tire valve
    • Twist off the spacer that holds the valve in place.
    • Push valve in toward wheel to release air pressure.
  6. Giant Reign 2 Wheel Spoke Replacement, Tire Rim: passo 6, immagine 1 di 3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: passo 6, immagine 2 di 3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: passo 6, immagine 3 di 3
    • Insert one tire lever between the tire and the rim.
    • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
    • Insert a second tire lever next to the first.
    • Slowly slide one tire lever around the rim until the tire is released from the rim.
  7. Giant Reign 2 Wheel Spoke Replacement, Tire Tube: passo 7, immagine 1 di 1
    • Using your hand, pull the tube completely out of the tire.
  8. Giant Reign 2 Wheel Spoke Replacement, Brake Rotor: passo 8, immagine 1 di 1
    • Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
    • Pull brake rotors off both sides of the wheel.
  9. Giant Reign 2 Wheel Spoke Replacement, Tire: passo 9, immagine 1 di 1
    • Pull the tire from the rim.
  10. Giant Reign 2 Wheel Spoke Replacement, Rim Tape: passo 10, immagine 1 di 1
    • Using a tire lever, push the rim tape aside to reveal the spoke nipple.
    • Using your fingers, pull off the old spoke nipple.
  11. Giant Reign 2 Wheel Spoke Replacement, Wheel Spoke: passo 11, immagine 1 di 1
    • Push out the old spoke from the hub.
  12. Giant Reign 2 Wheel Spoke Replacement: passo 12, immagine 1 di 2 Giant Reign 2 Wheel Spoke Replacement: passo 12, immagine 2 di 2
    • Insert a new 250mm spoke into the hub.
    • Align the spoke with the spoke nipple in the rim.
    • Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
  13. Giant Reign 2 Wheel Spoke Replacement: passo 13, immagine 1 di 1
    • Using an SW-1 spoke wrench, tighten the spoke.
Conclusione
Cal Poly, Team 9-14, Amido Fall 2012 Membro di Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,403
