Introduzione
Use this guide to replace the 9 Volt battery that powers the base
Unplug the device before proceeding. Remove the phone cord from the phone jack from the base of the headset.
  • Unplug the device before proceeding.
  • Remove the phone cord from the phone jack from the base of the headset.
    • Use a plastic opening tool to remove the phone cord.
Aggiungi Commento
Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
  • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
  • Remove the cord from the phone base.
Aggiungi Commento
Use finger to remove the battery cover. Use finger to remove the battery cover.
  • Use finger to remove the battery cover.
Aggiungi Commento
Conclusione
Cal Poly, Team 16-59, Forte Fall 2012 Membro di Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 561
