Parti
Nessuna parte richiesta.
Flip phone over so its backside is facing up.
  • Flip phone over so its backside is facing up.
Aggiungi Commento
Push from indentation and slide battery cover away from phone to remove battery cover.
  • Push from indentation and slide battery cover away from phone to remove battery cover.
Aggiungi Commento
Hold battery upwards so you see “This side up”
  • Hold battery upwards so you see “This side up”
Aggiungi Commento
Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
Aggiungi Commento
Using your plastic pry tool, slide the tool between the phone’s keypad cover and back cover. Using your plastic pry tool, slide the tool between the phone’s keypad cover and back cover.
  • Using your plastic pry tool, slide the tool between the phone’s keypad cover and back cover.
Aggiungi Commento
You should be able to see the motherboard. Don’t separate the two covers. They should be held together by a screw at the axis of the phone.
  • You should be able to see the motherboard. Don’t separate the two covers. They should be held together by a screw at the axis of the phone.
Aggiungi Commento
Conclusione
Jack Foley
Membro da: 25/04/2013
28 Reputazione
6 Guide realizzate
Cal Poly, Team 13-62, Johann Spring 2013 Membro di Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 260
