Introduzione
This repair is needed in situations where your keyboard stops working. If you have checked that all the keys are properly seated and that there is nothing blocking key movement, replacing the keyboard should correct the issue.
Parti
Nessuna parte richiesta.
Turn the laptop upside down and position it as shown in the image.
  • Turn the laptop upside down and position it as shown in the image.
Aggiungi Commento
Slide the locking switch towards the open lock picture. Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop. Once the laptop is disengaged, completely remove the battery from the laptop.
  • Slide the locking switch towards the open lock picture.
  • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
  • Once the laptop is disengaged, completely remove the battery from the laptop.
Aggiungi Commento
Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
  • Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
Aggiungi Commento
Remove the 4mm Phillips #0 screw that secures the keyboard. Remove the 4mm Phillips #0 screw that secures the keyboard.
  • Remove the 4mm Phillips #0 screw that secures the keyboard.
As I mentioned in another guide, seeing the battery in place here is a bit confusing.
Dan Brown - Replica
Reposition the laptop so that it is upright with the display open.
  • Reposition the laptop so that it is upright with the display open.
Aggiungi Commento
Carefully pry up on the right and left sides of the speaker cover panel. The panel has a cable that connects it to the laptop, so do not pull the panel completely away from the laptop. Instead, disconnect the panel and move it slightly so that it does not interfere with the keyboard. The panel has a cable that connects it to the laptop, so do not pull the panel completely away from the laptop. Instead, disconnect the panel and move it slightly so that it does not interfere with the keyboard.
  • Carefully pry up on the right and left sides of the speaker cover panel.
  • The panel has a cable that connects it to the laptop, so do not pull the panel completely away from the laptop. Instead, disconnect the panel and move it slightly so that it does not interfere with the keyboard.
Aggiungi Commento
Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard. Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
  • Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
Aggiungi Commento
Pull on the cord connecting the keyboard to the computer until it slides out. Be careful while removing the cord as it is very delicate.
  • Pull on the cord connecting the keyboard to the computer until it slides out.
  • Be careful while removing the cord as it is very delicate.
Thank you! This is a first time repair for me, and it worked!
As for step 8, my Gateway W350I has a cable retainer. The first time I tried the repair, the keyboard wouldn't work. Sure enough, the cable got loose after I tried putting it in. On the second attempt (after some research on my phone), I carefully nudged the tabs on the retainer 2 mm away from the connector, put the cable in, and nudged the tabs back into the connector. After the cable was locked, the keyboard worked perfectly.
JasonMath - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Spencer
Membro da: 22/09/2014
251 Reputazione
2 Guide realizzate
USF Tampa, Team 4-1, Brown Fall 2014 Membro di USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Membri
5 Guide realizzate
Great guide guys!
Stephan Williams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 630
