Salta al contenuto principale
Gateway SA1 Screen Replacement
Cosa ti serve
  1. Gateway SA1 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Screen Replacement: passo 2, immagine 1 di 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Screen Replacement, Screen: passo 3, immagine 1 di 2 Gateway SA1 Screen Replacement, Screen: passo 3, immagine 2 di 2
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
  4. Gateway SA1 Screen Replacement: passo 4, immagine 1 di 2 Gateway SA1 Screen Replacement: passo 4, immagine 2 di 2
    • Remove the six screw covers on the front bezel with the sharp point of the spudger.
    • The bottom two are more difficult to remove.
  5. Gateway SA1 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the six 5.9 mm Philips screws securing the screen bezel.
  6. Gateway SA1 Screen Replacement: passo 6, immagine 1 di 3 Gateway SA1 Screen Replacement: passo 6, immagine 2 di 3 Gateway SA1 Screen Replacement: passo 6, immagine 3 di 3
    • Remove the front bezel by prying it off with the wedged end of the spudger.
    • Verify that your spudger does not touch the LCD.
    • The screen inverter is now exposed below the LCD.
  7. Gateway SA1 Screen Replacement: passo 7, immagine 1 di 1
    • Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
  8. Gateway SA1 Screen Replacement: passo 8, immagine 1 di 2 Gateway SA1 Screen Replacement: passo 8, immagine 2 di 2
    • Use your finger, or the spudger, to pry the inverter board out.
    • This exposes the wires behind it.
  9. Gateway SA1 Screen Replacement: passo 9, immagine 1 di 1
    • Unplug the LCD back light cables from the right side of the screen inverter.
  10. Gateway SA1 Screen Replacement: passo 10, immagine 1 di 2 Gateway SA1 Screen Replacement: passo 10, immagine 2 di 2
    • Remove the six screws that mount the screen to the hinge mounts.
    • Two 2.5 mm Phillips screws.
    • Four 3.8 mm Phillips screws.
  11. Gateway SA1 Screen Replacement: passo 11, immagine 1 di 1
    • Unplug the cable from the webcam board.
    • Be gentle, do not use excessive force or you may break the connection.
  12. Gateway SA1 Screen Replacement: passo 12, immagine 1 di 1
    • Separate the screen from the display cover.
    • Do not touch the back of the screen.
  13. Gateway SA1 Screen Replacement: passo 13, immagine 1 di 2 Gateway SA1 Screen Replacement: passo 13, immagine 2 di 2
    • Remove the three tape strips that hold down the cables.
    • Be careful not to tear any of the tape. The piece holding down the webcam wires is especially delicate.
  14. Gateway SA1 Screen Replacement: passo 14, immagine 1 di 2 Gateway SA1 Screen Replacement: passo 14, immagine 2 di 2
    • Unplug the display data cable from the screen connector.
    • This connection is very fragile; do not use excessive force.
    • The screen should now be free from all wire connections.
  15. Gateway SA1 Screen Replacement: passo 15, immagine 1 di 1
    • Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
    • There will be two screws on either side of the mounting bracket.
  16. Gateway SA1 Screen Replacement: passo 16, immagine 1 di 1
    • You can now remove and replace the screen.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 24-20, Regan Spring 2010 Membro di Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 18,876
