Salta al contenuto principale
Gateway NV52 WiFi Card Replacement
Cosa ti serve
  1. Gateway NV52 WiFi Card Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 WiFi Card Replacement: passo 2, immagine 1 di 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 WiFi Card Replacement, WiFi Card: passo 3, immagine 1 di 1
    • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
  4. Gateway NV52 WiFi Card Replacement: passo 4, immagine 1 di 1
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
  5. Gateway NV52 WiFi Card Replacement: passo 5, immagine 1 di 1
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
Conclusione
Ruben
Membro da: 04/22/14
298 Reputazione
2 Guide realizzate
Cal Poly, Team 7-24, Regan Spring 2014 Membro di Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,241
