Introduzione
You will use the fan repair guide to get to the CPU. Then, you will use the lock to remove the CPU.
Place the laptop so the back cover is facing up.
  • Place the laptop so the back cover is facing up.
Aggiungi Commento
Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
Aggiungi Commento
Lift off the cover.
  • Lift off the cover.
Aggiungi Commento
Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
  • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
  • Pull the plastic part of the cable, not the wires, so that the plug does not break.
Aggiungi Commento
Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
Aggiungi Commento
The fan is permanently attached to the silver heat sink next to the RAM.
  • The fan is permanently attached to the silver heat sink next to the RAM.
  • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
  • Take out the screws in the numerical order shown on the heat sink.
Aggiungi Commento
Pull the fan and heat sink toward you at a 20 degree angle upward.
  • Pull the fan and heat sink toward you at a 20 degree angle upward.
Aggiungi Commento
The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
  • The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
  • You will hear a click as the lock unlocks.
Aggiungi Commento
Place your fingers on opposite edges of the green card.
  • Place your fingers on opposite edges of the green card.
  • Carefully lift the CPU upward.
Aggiungi Commento
Conclusione
Toni Pipes
Membro da: 05/10/2010
297 Reputazione
7 Guide realizzate
Cal Poly, Team 21-31, Regan Fall 2010 Membro di Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Membri
7 Guide realizzate
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 6,655
