Salta al contenuto principale
Gateway MD2614u Fan Replacement
Cosa ti serve
  1. Gateway MD2614u Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Fan Replacement: passo 2, immagine 1 di 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Fan Replacement: passo 3, immagine 1 di 1
    • Lift off the cover.
  4. Gateway MD2614u Fan Replacement, Fan: passo 4, immagine 1 di 1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Fan Replacement: passo 5, immagine 1 di 1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Fan Replacement: passo 6, immagine 1 di 1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Fan Replacement: passo 7, immagine 1 di 1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
Conclusione
Altre 2 persone hanno completato questa guida.
Toni Pipes
Membro da: 10/05/10
333 Reputazione
7 Guide realizzate
Cal Poly, Team 21-31, Regan Fall 2010 Membro di Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 4,913
