Introduzione
The cooling assembly is made up of a cooling fan and a large piece of copper to help dissipate heat out of the bottom of your laptop. Over time, the fan can wear out and it will need to be replaced.
Parti
Nessuna parte richiesta.
Loosen the seven 6 mm Phillips #0 screws on the back of the case. Leave all the screws in the back plate and so you don't lose them.
  • Loosen the seven 6 mm Phillips #0 screws on the back of the case.
  • Leave all the screws in the back plate and so you don't lose them.
Aggiungi Commento
Pull upwards on the top of the back cover to remove it. Pull upwards on the top of the back cover to remove it.
  • Pull upwards on the top of the back cover to remove it.
Aggiungi Commento
Remove the four 9 mm Phillips #0 screws from the cooling assembly.
  • Remove the four 9 mm Phillips #0 screws from the cooling assembly.
Aggiungi Commento
Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer. Gently flip the cooling fan assembly upside-down on the computer surface. Carefully grab the wire attached to the computer and pull away from the port.
  • Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
  • Gently flip the cooling fan assembly upside-down on the computer surface.
  • Carefully grab the wire attached to the computer and pull away from the port.
  • The cooling fan is now safe for removal.
Aggiungi Commento
When reinstalling heat sink and fans clean  off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
  • When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
  • If your unfamiliar with applying thermal paste How to Apply Thermal Paste
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Chris Naughton
Membro da: 07/04/2014
690 Reputazione
5 Guide realizzate
Cal Poly, Team 6-2, Forte Spring 2014 Membro di Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 339
