Introduzione
Once you've opened up the netbook to reach the monitor, the webcam can be easily replaced.
Parti
Nessuna parte richiesta.
Unlock the tab located in the top left corner of the netbook. The red tab indicated that the battery has been properly unlocked. Remove the battery.
  • Unlock the tab located in the top left corner of the netbook.
  • The red tab indicated that the battery has been properly unlocked.
  • Remove the battery.
  • When working with electronics, it is always wise to remove the power source before taking the device apart.
Aggiungi Commento
Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
Aggiungi Commento
Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here. Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
Aggiungi Commento
Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph. Don't use a screwdriver as a pry tool as shown in this example. Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
  • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
Aggiungi Commento
Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Aggiungi Commento
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage. Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
  • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
Aggiungi Commento
Pry the border around the monitor off of the top cover using a plastic opening tool, as shown. Be careful not to damage the computer screen in the process Be careful not to damage the computer screen in the process
  • Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
  • Be careful not to damage the computer screen in the process
Aggiungi Commento
Separate the monitor from the border cover once all snap connections have been pried apart. Separate the monitor from the border cover once all snap connections have been pried apart.
  • Separate the monitor from the border cover once all snap connections have been pried apart.
Aggiungi Commento
Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
  • Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
Aggiungi Commento
Take the screen out of the top cover. Take the screen out of the top cover.
  • Take the screen out of the top cover.
Aggiungi Commento
The webcam is located here, as shown. Disconnect the webcam from the wires attaching it to the computer.
  • The webcam is located here, as shown.
  • Disconnect the webcam from the wires attaching it to the computer.
  • Lift the webcam away from the top cover.
Aggiungi Commento
Conclusione
Lydia Benjock
Membro da: 18/10/2013
1.189 Reputazione
22 Guide realizzate
Clemson, Team 14-3, Benson Fall 2013 Membro di Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Membri
24 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 360
