Introduzione
Replacing the motherboard take quite a few steps, but it is doable.
Parti
Nessuna parte richiesta.
Unlock the tab located in the top left corner of the netbook. The red tab indicated that the battery has been properly unlocked. Remove the battery.
  • Unlock the tab located in the top left corner of the netbook.
  • The red tab indicated that the battery has been properly unlocked.
  • Remove the battery.
  • When working with electronics, it is always wise to remove the power source before taking the device apart.
Aggiungi Commento
Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
Aggiungi Commento
Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here. Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
Aggiungi Commento
Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph. Don't use a screwdriver as a pry tool as shown in this example. Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
  • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
Aggiungi Commento
Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Aggiungi Commento
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage. Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
  • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
Aggiungi Commento
The WiFi card is shown here. Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
  • The WiFi card is shown here.
  • Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
Aggiungi Commento
Disconnect the wires on the WiFi card.  This can be done easily by applying pressure to the connections until they pop off of the card. Disconnect the wires on the WiFi card.  This can be done easily by applying pressure to the connections until they pop off of the card.
  • Disconnect the wires on the WiFi card. This can be done easily by applying pressure to the connections until they pop off of the card.
Aggiungi Commento
Using a Phillips #00 screwdriver, remove the four (4) 5mm screws holding the motherboard in place.
  • Using a Phillips #00 screwdriver, remove the four (4) 5mm screws holding the motherboard in place.
Aggiungi Commento
Remove the motherboard by lifting it gently from the bottom cover.
  • Remove the motherboard by lifting it gently from the bottom cover.
  • This image is the rear view of the motherboard.
Aggiungi Commento
Conclusione
Lydia Benjock
Membro da: 18/10/2013
1.189 Reputazione
22 Guide realizzate
Clemson, Team 14-3, Benson Fall 2013 Membro di Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Membri
24 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,025
