Introduzione
Keys are easy to replace on a Gateway netbook. You can purchase keys online at Amazon, eBay, or the product page. Keys contain three parts: key cap, key retainer clip, and rubber cup. For this guide, we will replace the key cap.
Parti
Nessuna parte richiesta.
Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
  • Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
Aggiungi Commento
Insert a plastic opening tool under the key to be removed. Insert a plastic opening tool under the key to be removed.
  • Insert a plastic opening tool under the key to be removed.
Aggiungi Commento
Put the opening tool underneath the key. Use force until the key pops up.
  • Put the opening tool underneath the key. Use force until the key pops up.
Aggiungi Commento
  • To replace the key, follow these instructions, but do them in reverse order (i.e., use the plastic opening tool to put the key back in place).
Aggiungi Commento
Conclusione
My Linh Pham
Membro da: 11/03/2014
301 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 230
