Introduzione
If you have a Phillips #0 screwdriver, you can easily replace the 3G card.
Parti
Nessuna parte richiesta.
Unlock the tab located in the top left corner of the netbook. The red tab indicated that the battery has been properly unlocked. Remove the battery.
  • Unlock the tab located in the top left corner of the netbook.
  • The red tab indicated that the battery has been properly unlocked.
  • Remove the battery.
  • When working with electronics, it is always wise to remove the power source before taking the device apart.
Aggiungi Commento
The 3G card is located under this cover.
  • The 3G card is located under this cover.
Aggiungi Commento
Use the Phillips #0 screwdriver to remove one (1) 5mm screw. Use the plastic opening tools to lift up the cover. Use the plastic opening tools to lift up the cover.
  • Use the Phillips #0 screwdriver to remove one (1) 5mm screw.
  • Use the plastic opening tools to lift up the cover.
Aggiungi Commento
Using the Phillips #0 screwdriver, remove one (1) 5mm screw holding the card in place.
  • Using the Phillips #0 screwdriver, remove one (1) 5mm screw holding the card in place.
Aggiungi Commento
Remove the 3G card from the computer by lifting the card up from the bottom.
  • Remove the 3G card from the computer by lifting the card up from the bottom.
Aggiungi Commento
Notice the two wires connected to the card. Gently detach the wires from the card. The metal portions will "pop" off
  • Notice the two wires connected to the card.
  • Gently detach the wires from the card. The metal portions will "pop" off
Aggiungi Commento
Conclusione
Lydia Benjock
Membro da: 18/10/2013
1.189 Reputazione
22 Guide realizzate
Clemson, Team 14-3, Benson Fall 2013 Membro di Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Membri
24 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 482
