Introduzione
Removal of the system fan. when following the keyboard instructions there is no need to unplug it only fold it back to gain access to the fan.
Parti
Nessuna parte richiesta.
Flip the laptop over. Slide the battery release tab to the right.
  • Flip the laptop over. Slide the battery release tab to the right.
Aggiungi Commento
Lift the battery out.
  • Lift the battery out.
Aggiungi Commento
Remove the 5 screws holding the keyboard in place.
  • Remove the 5 screws holding the keyboard in place.
Aggiungi Commento
CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge. DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
  • CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge.
  • DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
  • Follow the black ribbon cable to the connector and gently pull straight up.
Aggiungi Commento
Unscrew the 4 captive screws. Unplug fan from the system and pull it out. The fan unit should slide forward before coming free.
  • Unscrew the 4 captive screws.
  • Unplug fan from the system and pull it out. The fan unit should slide forward before coming free.
Aggiungi Commento
Conclusione
Elizabeth Mazer
Membro da: 14/10/2010
78 Reputazione
20 Guide realizzate
Cal Poly, Team 20-10, Maness Fall 2010 Membro di Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Membri
22 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,048
