Introduzione
Removal of LCD display
Parti
Nessuna parte richiesta.
Flip the laptop over. Slide the battery release tab to the right.
  • Flip the laptop over. Slide the battery release tab to the right.
Aggiungi Commento
Lift the battery out.
  • Lift the battery out.
Aggiungi Commento
Insert spudger between sysrq and ins keys.
  • Insert spudger between sysrq and ins keys.
  • Gently lift power button panel from the right to left.
Aggiungi Commento
Remove 5 screws.
  • Remove 5 screws.
  • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
  • Remove hinge covers.
Aggiungi Commento
Gently unplug LCD from system board.
  • Gently unplug LCD from system board.
Aggiungi Commento
Remove 6 screws holding LCD to hinge.
  • Remove 6 screws holding LCD to hinge.
Aggiungi Commento
Pull LCD away from case.
  • Pull LCD away from case.
Aggiungi Commento
Conclusione
Elizabeth Mazer
Membro da: 14/10/2010
78 Reputazione
20 Guide realizzate
Cal Poly, Team 20-10, Maness Fall 2010 Membro di Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Membri
22 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,683
