Introduzione
These instructions will teach you how to replace your LCD screen.
Parti
Nessuna parte richiesta.
Flip the device to the backside, and locate the metal tab at the center of the back cover.
  • Flip the device to the backside, and locate the metal tab at the center of the back cover.
Aggiungi Commento
Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
Aggiungi Commento
Lift the battery plate off to either insert or remove 2 AA batteries. Lift the battery plate off to either insert or remove 2 AA batteries.
  • Lift the battery plate off to either insert or remove 2 AA batteries.
Aggiungi Commento
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body. With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
Aggiungi Commento
With the pick side of a spudger (or tweezers), peel the sticky tape from the device. With the pick side of a spudger (or tweezers), peel the sticky tape from the device. With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
Aggiungi Commento
Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
  • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
  • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
  • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
Aggiungi Commento
With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard. With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
Aggiungi Commento
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
Aggiungi Commento
There are no screws holding the motherboard in place.
  • There are no screws holding the motherboard in place.
  • Carefully lift the motherboard from the case.
Aggiungi Commento
With the pointed end of a spudger (or the  small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector. Gently pull the wire ribbon from the white connector.
  • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
  • Gently pull the wire ribbon from the white connector.
Aggiungi Commento
After removing the motherboard, locate the two #1 Philips screws. Carefully remove both screws. Carefully remove both screws.
  • After removing the motherboard, locate the two #1 Philips screws.
  • Carefully remove both screws.
Aggiungi Commento
Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws. Do not remove the LSC screen by lifting the sides, only the area that held the two #1 Philips screws.
  • Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws.
  • Do not remove the LSC screen by lifting the sides, only the area that held the two #1 Philips screws.
Aggiungi Commento
Insert the new LCD screen in the device.
  • Insert the new LCD screen in the device.
Hi, Sir, i need display units for garmin etrexH, and etrex10, please let me k now the unit cost and where i can buy...thanks
shiva raj - Replica
Hi, I was wondering where I could get one new screen for my garmin etrex legend HCx.
Thank you very much,
Jordi
Arctictern - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
Lauren Noyes
Membro da: 17/10/2010
206 Reputazione
3 Guide realizzate
Cal Poly, Team 21-30, Regan Fall 2010 Membro di Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Membri
5 Guide realizzate
where can I find the LCD test
carlos gomes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 60
Tutti i Tempi: 9,134
