Salta al contenuto principale
Garmin StreetPilot c330 Speakers Replacement
Cosa ti serve
  1. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: passo 1, immagine 1 di 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: passo 1, immagine 2 di 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: passo 1, immagine 3 di 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Speakers Replacement: passo 2, immagine 1 di 3 Garmin StreetPilot c330 Speakers Replacement: passo 2, immagine 2 di 3 Garmin StreetPilot c330 Speakers Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Speakers Replacement: passo 3, immagine 1 di 2 Garmin StreetPilot c330 Speakers Replacement: passo 3, immagine 2 di 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Speakers Replacement: passo 4, immagine 1 di 3 Garmin StreetPilot c330 Speakers Replacement: passo 4, immagine 2 di 3 Garmin StreetPilot c330 Speakers Replacement: passo 4, immagine 3 di 3
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Speakers Replacement: passo 5, immagine 1 di 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Speakers Replacement, Battery: passo 6, immagine 1 di 3 Garmin StreetPilot c330 Speakers Replacement, Battery: passo 6, immagine 2 di 3 Garmin StreetPilot c330 Speakers Replacement, Battery: passo 6, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Speakers Replacement: passo 7, immagine 1 di 3 Garmin StreetPilot c330 Speakers Replacement: passo 7, immagine 2 di 3 Garmin StreetPilot c330 Speakers Replacement: passo 7, immagine 3 di 3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
  8. Garmin StreetPilot c330 Speakers Replacement, Speakers: passo 8, immagine 1 di 2 Garmin StreetPilot c330 Speakers Replacement, Speakers: passo 8, immagine 2 di 2
    • Carefully use the spudger to pry the speakers from the outer casing.
    • Once removed, you may use a soldering iron to remove the wires from the speakers.
Conclusione
Michael
Membro da: 10/07/10
107 Reputazione
1 Guida realizzata
Cal Poly, Team 22-1, Maness Fall 2010 Membro di Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,711
