Use a plastic spudger tool to remove the plastic frame. Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out. Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out.
  • Use a plastic spudger tool to remove the plastic frame.
  • Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out.
Aggiungi Commento
Use a phillips head screw driver to remove all four screws in the corners around the screen. Set the screws aside for later. Set the screws aside for later.
  • Use a phillips head screw driver to remove all four screws in the corners around the screen.
  • Set the screws aside for later.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Gently pull from both ends to separate the front panel from the back. Do not force the pieces apart wider than the length of the connecting wires or you will damage the wiring.
  • Gently pull from both ends to separate the front panel from the back.
  • Do not force the pieces apart wider than the length of the connecting wires or you will damage the wiring.
Aggiungi Commento
Locate the white wire clip.  Gently unplug it using either your fingers or tweezers. Locate the white wire clip.  Gently unplug it using either your fingers or tweezers. Locate the white wire clip.  Gently unplug it using either your fingers or tweezers.
  • Locate the white wire clip. Gently unplug it using either your fingers or tweezers.
Aggiungi Commento
Carefully expose both halves of the device.
  • Carefully expose both halves of the device.
  • Be sure to not pull the two halves apart too hard to avoid damaging the black wire.
Aggiungi Commento
Conclusione
Your device should be ready to use once more.
Altre 2 persone hanno completato questa guida.
Adrian Leon
Membro da: 07/10/2010
169 Reputazione
3 Guide realizzate
Cal Poly, Team 22-1, Maness Fall 2010 Membro di Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,767
