Introduzione
If your power button is defective, replace the old one with the new power button.
Remove the barcode sticker at the bottom of the device.
  • Remove the barcode sticker at the bottom of the device.
Aggiungi Commento
Remove two 8.4 mm T5 screws from the bottom of the device.
  • Remove two 8.4 mm T5 screws from the bottom of the device.
Aggiungi Commento
Using a plastic opening tool, carefully pry open the device. Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  • Using a plastic opening tool, carefully pry open the device.
  • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
turn the unit around
Andrew Hayden - Replica
Since there is no replacement speaker whats the point of this process?
greg - Replica
Very detailed set of instructions! Does anyone known the thread size of the screws in step 2? 8.4 mm T5 screws: is the length of the screw (8.4 mm) ,and the head specification (T5- size of screw driver). I need the actual thread specification. I lost one of the screws and the other one 's head is stripped. I need to replace both screws.
Harold Schultz - Replica
Remove the power button. Remove the power button.
  • Remove the power button.
Where can I buy the button
milosvalek - Replica
Conclusione
Timothy
Membro da: 26/01/2012
35 Reputazione
3 Guide realizzate
Cal Poly, Team 9-3, Regan Winter 2012 Membro di Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 39
Tutti i Tempi: 9,063
