Introduzione
In this guide the repairer replaces the LCD display of the device by carefully prying apart the components with one's hands.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • None
Estimated Duration: 5 minutes
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
Aggiungi Commento
Hold the front panel plastic and screen as shown.
  • Hold the front panel plastic and screen as shown.
  • Gently apply pressure on the left and top left corner to allow the screen to come out of the plastic shell.
Aggiungi Commento
Once the top-left corner is out, carefully start detaching the bottom of the screen, starting from the bottom left.
  • Once the top-left corner is out, carefully start detaching the bottom of the screen, starting from the bottom left.
Aggiungi Commento
Finally, gently pull the screen out of the right side of the plastic shell.
  • Finally, gently pull the screen out of the right side of the plastic shell.
Aggiungi Commento
The screen should now be completely detached.
  • The screen should now be completely detached.
  • Insert new, functional display screen.
Aggiungi Commento
Conclusione
Matt West
Membro da: 18/04/2013
22 Reputazione
4 Guide realizzate
Cal Poly, Team 13-65, Johann Spring 2013 Membro di Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 449
