Introduzione
In this guide the repairer replaces the battery of the device by disassembling it to expose the motherboard, which in turn allows access to the battery.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • Fine Point Tweezers
  • Spudger
Estimated Duration: 10 minutes
Parti
Nessuna parte richiesta.
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
Aggiungi Commento
Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
Aggiungi Commento
The motherboard will now freely separate from the back casing; lay it flat next to the housing. The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
Aggiungi Commento
Disconnect the speaker and battery from their terminals on the motherboard.  This should disconnect the motherboard completely from the back panel. It is recommended that you use tweezers or the spudger for precision.
  • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • It is recommended that you use tweezers or the spudger for precision.
Aggiungi Commento
Using the flat edge of the spudger from above, gently pry the battery away from the plastic. Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
  • Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
Aggiungi Commento
The battery should now be completely separated from the other components.
  • The battery should now be completely separated from the other components.
  • Insert new, functional battery.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 13-65, Johann Spring 2013 Membro di Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,244
