Introduzione
If the buttons are unresponsive or sticking, the keypad may be compromised and need to be replaced. This is a guide to replace the keypad buttons of the Garmin GPSmap 60CSx.
Cosa ti serve
Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
Remove the black, yellow, blue, and red wires connected to the PCB with light force.
Altre 3 persone hanno completato questa guida.
