Salta al contenuto principale
Garmin Dezl 760LMT Battery Replacement
Cosa ti serve
  1. Garmin Dezl 760LMT Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Garmin Dezl 760LMT Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Battery Replacement: passo 2, immagine 1 di 3 Garmin Dezl 760LMT Battery Replacement: passo 2, immagine 2 di 3 Garmin Dezl 760LMT Battery Replacement: passo 2, immagine 3 di 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Battery Replacement: passo 3, immagine 1 di 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Battery Replacement, Battery: passo 4, immagine 1 di 2 Garmin Dezl 760LMT Battery Replacement, Battery: passo 4, immagine 2 di 2
    • This photo shows the use of a tool that is not ESD safe. Use a nylon spudger to complete this step.
    • Use a nylon spudger to pry the battery from the device.
    • During reassembly, place double-sided electrical tape under the battery before pressing it into its slot.
  5. Garmin Dezl 760LMT Battery Replacement: passo 5, immagine 1 di 2 Garmin Dezl 760LMT Battery Replacement: passo 5, immagine 2 di 2
    • Grasp the battery wire near the motherboard and lift upward to detach the connector.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 4-2, Passmore Fall 2016 Membro di USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Membri
6 Guide realizzate
2 Commenti
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
Pissedoff - Replica
you have to be more careful with your stuff dude..
Bealphares Voluptarius -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,903
