Salta al contenuto principale
Game Boy Pocket Motherboard Replacement
Cosa ti serve
  1. Game Boy Pocket Motherboard Replacement, Back Cover: passo 1, immagine 1 di 3 Game Boy Pocket Motherboard Replacement, Back Cover: passo 1, immagine 2 di 3 Game Boy Pocket Motherboard Replacement, Back Cover: passo 1, immagine 3 di 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Motherboard Replacement: passo 2, immagine 1 di 3 Game Boy Pocket Motherboard Replacement: passo 2, immagine 2 di 3 Game Boy Pocket Motherboard Replacement: passo 2, immagine 3 di 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket Motherboard Replacement: passo 4, immagine 1 di 3 Game Boy Pocket Motherboard Replacement: passo 4, immagine 2 di 3 Game Boy Pocket Motherboard Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Motherboard Replacement: passo 5, immagine 1 di 2 Game Boy Pocket Motherboard Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Motherboard Replacement: passo 6, immagine 1 di 2 Game Boy Pocket Motherboard Replacement: passo 6, immagine 2 di 2
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
Adriana Rahrig
Membro da: 10/07/14
1.523 Reputazione
5 Guide realizzate
USF Tampa, Team 1-1, Leahy Fall 2014 Membro di USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 102
Tutti i Tempi: 5,193
