Introduzione
How to remove the back panel from a Game Boy Advance.
Parti
Nessuna parte richiesta.
Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away.
  • Take the battery cover off by releasing the locking tab and hinging the cover away.
Aggiungi Commento
Remove the six back panel screws using a Tri-wing Screwdriver.
  • Remove the six back panel screws using a Tri-wing Screwdriver.
Aggiungi Commento
Remove bottom back panel screw with a Phillips #1 screw driver.
  • Remove bottom back panel screw with a Phillips #1 screw driver.
We recommend you change the the screw head to a Phillips 1 so you don't strip the screw. (Something we experienced)
Adriano Agostino - Replica
Remove the back panel by pulling away with one hand and the front secured in the other hand.
  • Remove the back panel by pulling away with one hand and the front secured in the other hand.
  • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Aldo Corona
Membro da: 25/01/2010
550 Reputazione
12 Guide realizzate
Cal Poly, Team 16-29, Maness Winter 2010 Membro di Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,916
