Release the 3 clips that attach the front fan guard to the rear fan guard. Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  • Release the 3 clips that attach the front fan guard to the rear fan guard.
  • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
Aggiungi Commento
Pull the front fan guard off.
  • Pull the front fan guard off.
Aggiungi Commento
Remove the spinner from the center of the fan blade. Remove the spinner from the center of the fan blade.
  • Remove the spinner from the center of the fan blade.
Aggiungi Commento
The fan blades should now be easy to lift up.
  • The fan blades should now be easy to lift up.
  • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Alan Su
Membro da: 03/10/2012
513 Reputazione
6 Guide realizzate
Cal Poly, Team 24-28, Regan Fall 2012 Membro di Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Membri
10 Guide realizzate
Where do you buy the fan blades?
charlie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 113
Tutti i Tempi: 1,943
