Turn locking device on back side of phone marked by the rectangle counter clockwise. Turn locking device on back side of phone marked by the rectangle counter clockwise.
  • Turn locking device on back side of phone marked by the rectangle counter clockwise.
Aggiungi Commento
Remove battery by grabbing the sides and pulling upward.
  • Remove battery by grabbing the sides and pulling upward.
  • If battery was malfunctioning due to age or corrosion, there may be battery acid residue on the battery and the back of the phone. Wear gloves in order to prevent skin irritation.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws. Once all screws are removed the case will easily lift off. Once all screws are removed the case will easily lift off.
  • Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws.
  • Once all screws are removed the case will easily lift off.
Aggiungi Commento
With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place. With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
  • With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
Aggiungi Commento
With screw removed, gently pull the antenna outward. It should slide out easily. With screw removed, gently pull the antenna outward. It should slide out easily.
  • With screw removed, gently pull the antenna outward. It should slide out easily.
Aggiungi Commento
Conclusione
troy
Membro da: 11/03/2013
1 Reputazione
4 Guide realizzate
Clemson, Team 13-3, Benson Spring 2013 Membro di Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 336
