There are 4 black screws that need to be removed on the top of the lid.  A 1.5mm flathead screwdriver will work on the star shaped screw heads.
  • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
  • Make note that two of the screws closest to the hinge are longer than the other two.
Aggiungi Commento
Remove the two side screws. When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
  • Remove the two side screws.
  • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
Aggiungi Commento
Use a plastic opening tool to remove the screen cover from the rest of the lid. Use a plastic opening tool to remove the screen cover from the rest of the lid.
  • Use a plastic opening tool to remove the screen cover from the rest of the lid.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Your phone should look like the picture to the left. If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
  • Your phone should look like the picture to the left.
  • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
Aggiungi Commento
Remove one screw located on the left side of the phone with the pictured orientation in mind. This will release the logic board from the back case. Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
  • Remove one screw located on the left side of the phone with the pictured orientation in mind.
  • This will release the logic board from the back case.
  • Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
Aggiungi Commento
Pull the logic board out with a pry stick gently from bottom to top at the current orientation. The ribbon cable will be connected underneath the logic board.  A small amount of force is required to disconnect them. Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
  • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
  • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
  • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
Aggiungi Commento
Lift speaker towards yourself out of the white plastic container. Gently unplug the ribbon by pulling it to the left with the pictured orientation in mind.
  • Lift speaker towards yourself out of the white plastic container.
  • Gently unplug the ribbon by pulling it to the left with the pictured orientation in mind.
  • Be careful when unplugging connector as the ribbon connecting piece is extremely fragile.'
Aggiungi Commento
Conclusione
Raymond Caulder
Membro da: 11/03/2013
22 Reputazione
6 Guide realizzate
Clemson, Team 13-3, Benson Spring 2013 Membro di Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 239
