Locate the two clips on the bottom of the computer that support the battery.
  • Locate the two clips on the bottom of the computer that support the battery.
Aggiungi Commento
Using your fingers,  push the clips inward and then upward.
  • Using your fingers, push the clips inward and then upward.
  • Lift the battery out of the computer.
Aggiungi Commento
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer. Use a spudger to lift the back of the hinge cover on the left and right sides of the computer. Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Aggiungi Commento
Lay the computer flat on a stable surface with the monitor pointing away from you.
  • Lay the computer flat on a stable surface with the monitor pointing away from you.
Aggiungi Commento
Use a spudger to partially lift the hinge cover. Use a spudger to partially lift the hinge cover. Use a spudger to partially lift the hinge cover.
  • Use a spudger to partially lift the hinge cover.
Aggiungi Commento
The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly. Lift the hinge cover enough to expose the ribbon cable.
  • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
  • Lift the hinge cover enough to expose the ribbon cable.
Aggiungi Commento
Disconnect the ribbon cable from the  motherboard and remove the hinge cover from the computer. Disconnect the ribbon cable from the  motherboard and remove the hinge cover from the computer.
  • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
Aggiungi Commento
The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly. Lift the keyboard enough to expose the ribbon cable. Lift the keyboard enough to expose the ribbon cable.
  • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
  • Lift the keyboard enough to expose the ribbon cable.
Aggiungi Commento
Use a spudger to release the ribbon cable from the motherboard. Use a spudger to release the ribbon cable from the motherboard.
  • Use a spudger to release the ribbon cable from the motherboard.
Aggiungi Commento
After the ribbon has been detached, carefully remove the keyboard. After the ribbon has been detached, carefully remove the keyboard.
  • After the ribbon has been detached, carefully remove the keyboard.
Aggiungi Commento
Remove the following screws, all labeled "3."
  • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
  • Remove the following screw, labeled "15."
    • One 17.81mm screw.
Aggiungi Commento
Lift the cover with fingers and remove. Lift the cover with fingers and remove. Lift the cover with fingers and remove.
  • Lift the cover with fingers and remove.
Aggiungi Commento
Remove labeled screws.
  • Remove labeled screws.
Aggiungi Commento
Remove the screws from the bottom of the hinge as shown in the image.
  • Remove the screws from the bottom of the hinge as shown in the image.
Aggiungi Commento
Use a spudger to detach and remove cables from the motherboard. Use a spudger to detach and remove cables from the motherboard. Use a spudger to detach and remove cables from the motherboard.
  • Use a spudger to detach and remove cables from the motherboard.
Aggiungi Commento
Unplug highlighted cables from the wireless module. Unplug highlighted cables from the wireless module. Unplug highlighted cables from the wireless module.
  • Unplug highlighted cables from the wireless module.
Aggiungi Commento
Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body. Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body. Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
  • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
Aggiungi Commento
Remove the 4 labeled screws.
  • Remove the 4 labeled screws.
Aggiungi Commento
Remove screws from bottom of laptop as shown in the picture.
  • Remove screws from bottom of laptop as shown in the picture.
Aggiungi Commento
Lift the palm rest cover from the base of the laptop.
  • Lift the palm rest cover from the base of the laptop.
  • You may use spudger if needed, lift from the front corners as shown.
Aggiungi Commento
Great job! You have successfully removed the old palm rest cover.
  • Great job! You have successfully removed the old palm rest cover.
Aggiungi Commento
Push securing clips outward, the wireless module will pop out. Remove the wireless module. Remove the wireless module.
  • Push securing clips outward, the wireless module will pop out.
  • Remove the wireless module.
Aggiungi Commento
A picture of the removed wireless module is shown to the left.
  • A picture of the removed wireless module is shown to the left.
Aggiungi Commento
Conclusione
Neil Daniels
Membro da: 17/01/2011
1.276 Reputazione
11 Guide realizzate
Cal Poly, Team 5-18, Amido Winter 2011 Membro di Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,107
